'99 Ranger Transmission electrical problems?
Old 10-17-04, 07:02 PM
cragmire
1999 ranger w/ 2.5L engine, automatic. While driving down the road the transmission started slipping, ABS light came on, speedometer stopped working, then check engine light came on. Now will not shift out of low gear as well as the other fore mentioned problems. All fuses check good.
Old 10-18-04, 04:37 AM
the_tow_guy's Avatar
Received 181 Upvotes on 143 Posts
This might seem like out of left field, but I would start with a thorough electrical system check - battery condition and alternator output. Everything you mentioned has electrical/electronic parts that could be effected by low voltage.
Old 10-25-04, 04:17 PM
cragmire
Turns out the speed sensor in the back end went out.
Old 04-16-08, 07:04 PM
pbaxter's Avatar
Plug on the side of the trans
I had to work on my daughers 1999 ranger found that had to put a tie strap a round the connecter to hold it tight. I am not saying that you may have to but I replace speed sensor and a few days later it happened again.
