dash lights 1995 gmc truck
Old 10-20-04, 02:47 PM
bluboy
Question dash lights 1995 gmc truck
my dash lights only light up about half of the instrument cluster,they were dim on that same side before i changed the bulbs ,now they won't work at all.anybody got any ideas? thanks
Old 10-21-04, 02:01 PM
Do you have a wiring diagram for the dash circuits?Did you use the correct bulb number?I don't recall how the back of a 95 cluster is but the printed circuit could be bad or the cluster itself.You will need to confirm power and ground to make a diagnosis and you need the diagram for that.
Old 10-29-04, 11:32 AM
Harley8879
I have a 94 C1500 and the lights from the radio straight down went out. I've looked into it and the printed circuit goes bad. I have met MANY people with the same problem.
