93 Grand Am Questions
Old 10-20-04, 05:40 PM
B
big Don
It has a quad4 Vin#1G2NE1435PM627737. I don't know which engine? Advance Auto told me I should have an A in the #.I'm trying to get the
starter off to get checked.Davo advised me but
I still can't find all bolts. I think I have the bottom bolt out but not sure
if their 2 or 3 bolts.I have bracket removed.
Old 10-21-04, 04:13 AM
the_tow_guy's Avatar
Received 45 Votes on 36 Posts
The 8th position is the engine. I believe yours is a L4-138 2.3L SOHC, but one of the GM pro's should be along to confirm that.
Old 10-21-04, 07:42 AM
B
big Don
Thanks a millions.
Old 10-21-04, 01:50 PM
D
Only 2 bolts 1 from the engine side(lower bolt)1 from the trans side(upper bolt).Do you have the air intake removed so you can get in there?Your engine code is #3.
Old 10-21-04, 02:49 PM
B
big Don
Do not have air intate out but it"s on the way now never had a problem with a starter before.Thanks a million and am glad wife found this board.It is way cool that you guys help so many out.
Old 10-21-04, 04:38 PM
D
Don't take the intake manifold off just the hose and stuff that goes to it.
