vac. tests
Old 10-23-04, 06:19 PM
C
cbmf
Question vac. tests
I have a 85 s-10 that has no power. It hesitates when accelerates. I have installed a new TBS and vac. gauge reads normal
Old 10-23-04, 08:22 PM
billys68ss's Avatar
We need more information. What engine? Miles? Other than poor acceleration what else is it doing? Or not doing?
Hope this helps ya,
Billy
Old 10-24-04, 08:04 AM
C
cbmf
vac. leak 85 S-10
It is a
85 S-10
2.5 liter 4 cyl
TBI
recently cleaned out the tbi and the serverely plugged Egr port
replaced the tps and idle air control valve
the engine has 140k miles
idle is fine maybe alittle high
hesitates when the gas peddle is pushed (only under load)
computer reads lean mixture
vac gauges normal but drops if I push the accelerator
Old 10-24-04, 08:39 AM
D
Check the fuel pressure during the failure and also check the exhaust for a restriction ie,plugged cat conv.
