Cutlass Calais Transmission Problem
Old 10-23-04, 09:44 PM
G
Gin51
My brother's 1989 Cutlass Calais (3.3 engine) automatic transmission won't shift from 2nd to 3rd at normal speed. It will shift into 3rd at higher speeds of 60 to 65 mph.
The other gears work fine. Is this a sign that the transmission is shot or could it be something else?
Old 10-24-04, 06:00 PM
A
yep sounds like its slippen check fluid for contamination and couler try fluid and filter change add some lucus you may get a bit more time
