ABS code
Old 10-24-04, 07:21 PM
G
grindall
Question ABS code
hello
cool site here.
lots of probs lately.newest one is.
ABS light stayin on.
garage did scan.print out says.code 81 open short in brake light switch circuit,brake switch fail.
does it simply mean replace brake light switch??
Or am i gonna have to see the experts.brake light part of circuit workin fine.
Old 10-24-04, 08:06 PM
T
Do your brake lights work?
Old 10-24-04, 08:54 PM
G
grindall
yep,that circuit is aok.
Old 10-25-04, 06:48 AM
T
You'll probably need an electric diagram of the ABS circuit on this car. It may use the brake control module for some aspects. Most brake switches have 2 actual switches in them, one for the light and one for the cruise control. But if your brake lights work, and the cruise dissengages when you press on the brakes the switch is ok. The ABS controller probably uses on output of the brake control module to sense brake application.
