Changing Water Pump
Old 10-24-04, 08:25 PM
W
wade1555
Changing Water Pump
Does anyone know where online I can get step by step instructions to change a water pump on a 2000 Chevrolet Venture V-6? Any assistance you can provide would be greatly appreciated.
Old 10-25-04, 04:04 AM
the_tow_guy's Avatar
Received 44 Votes on 36 Posts
Go to www.alldata.com and purchase a subscription. Alldata is the same info garages use and if you are going to have the vehicle for a while, it'll pay for itself.
Old 10-25-04, 06:42 AM
T
It will probably be driven by the timing belt since it's a front whell drive van, which is going to be a long and somewhat complicated process.
I agree, AllData is much better then a Chilton or Haynes, but make sure you have a fast printer or a computer in the garage.
Old 10-25-04, 05:24 PM
Desi501's Avatar
It is the easiest water pump I have ever changed in my life. I can do one in 5-10 minutes. Here's alldata's instructions.
Drain the cooling system until the coolant is below the level of the water pump. Refer to Draining and Filling Cooling System.
Remove the drive belt guard.
Loosen the water pump pulley bolts.
Remove the drive belt. Refer to Drive Belt Replacement.
Remove the water pump pulley bolts.
Remove the water pump pulley.
Remove the water pump bolts.
Remove the water pump.
Remove the water pump gasket.
Clean the water pump mating surfaces.
Installation Procedure
Install the water pump gasket.
Install the water pump. Notice: Refer to Fastener Notice in Service Precautions.
Install the water pump bolts.
Tighten the bolts to 10 Nm (89 inch lbs.).
Install the water pump pulley. Loosely install the mounting bolts.
Install the drive belt. Refer to Drive Belt Replacement.
Install the water pump pulley bolts.
Tighten the bolts to 25 Nm (18 inch lbs.).
Install the drive belt guard.
Fill the cooling system. Refer to Draining and Filling Cooling System.
Inspect the cooling system for leaks.
