Valve adjustment -97 Mazda Protege
Old 10-25-04, 09:39 AM
P
I might purchase a '97 Mazda Protege w/ 50,000 miles. A little research showed the 1.5l engine to not have hydraulic lifters. What is required to adhust these? I read that shims are used. I have adjusted valves on old VW's for years and that is a simple job, but shims are not used on VW.
How do you adjust the valves on the Mazda? Any comments on that car? Anything to look for?
Old 10-25-04, 10:39 AM
A
valve clearance is for both intake and exhause
as follows>>
.25-.31 mm or .010-.012 inch engine cold
there are shims there is a special tool used to lower tappet to gain clearance to change shim
