Headlights flikering
stix309's Avatar
10-28-04, 04:39 AM   #1
stix309
I have a 93 Ford Aerostar, just recently my headlights have started flikering from the headlights to the daytime running lights after the headlights have been on for some time, this happens randomly and constantly. I'm not sure if the headlight switch or the high/low beam switch is the problem or is there a relay somewhere that is faulty. This happens in either high or low beam and only happens after about 15min of operation. Is there a wiring diagram I can use to find the problem, or has anyone ever dealt with this before.
Thanks in advance!!!!
AutoDoc's Avatar
10-28-04, 05:55 AM   #2
I have had to change many DRL Modules in these usuly located lower rad suport left side
sicando's Avatar
10-29-04, 09:48 AM   #3
sicando
I had this same problem and I guess I tried to make it more complicated than it was......I had a lose battery cable to the battery. Lights would flicker because of bad contact every now & again. Just a idea for you to check.
