Ford E-150 ABS Codes
Old 10-29-04, 05:11 AM
msceyenna
I've got a '96 E-150 club wagon with 4 wheel abs (5.8liter) and I get multiple codes. Codes are:
c1145: right front abs sensor ckt malfunction
c1198: left front iso inlet valve ckt malfunction
c1206: rear iso inlet valve ckt malfunction
c1214: right front iso inlet valve ckt malfunction
now, my question is : does anyone know if a single component failure can set all of these codes? it seems as though the right front sensor is bad but maybe the other three codes are being set by one single faulty component.
any thoughts?
Old 10-29-04, 05:58 AM
well if you know for sure the one is bad than change it than clear codes and re drive see what comes back or if your not 1005 sure clear codes and test drive and when the lamp comes on see what is there and start there
if you can scan data while you drive this will help you emensly
Old 10-29-04, 03:22 PM
I would lean towards a brake pressure modulator valve or a antilock brake module.The price for it won't be cheap for either one and some vehicles combine the two.Pull the connector off the abs unit and look for corrosion.It should not affect your regular brakes in any way.
