96 chev trk -5.0 heater inlet +outlet hoses
Old 10-29-04, 05:26 AM
elybrook
I have a 96 c1500 chev trk w/ 5.0 and i cant find which hose is the inlet to the heater core. I am installing a coolant pre-heater to help start on those cold morns. I need to run the outlet of the pre-heater to the outlet of the heater core, so the per-heated coolant can go to the eng. block.
I have a hose coming from the top of the water pump. and one hose coming from the top of the intake manifold. both seem to get warm at the same time so i cant tell by feeling which hose gets hot first ...
thank you
Old 10-29-04, 05:31 AM
the_tow_guy's Avatar
The one from the manifold to the core would be the "hot" side. The hose going to the water pump would be the "return".
Old 10-29-04, 05:37 AM
elybrook
Red face thanks tow guy
i have already installed the "Y" fitting in the hot side -- do you think this will cause any probs with the eng cooling or heater core working prop.
thanks
