No start with no spark
Old 10-29-04, 05:09 PM
pt_fixer's Avatar
I've got a 97 Ford Probe with a 2.0. (Same engine as Mazda 626 with 2.0) I've been getting an intermittent no start which I found is due to no spark. The coil is getting the proper voltage, but is not getting a 'signal'(ground) from the computer. No codes present. This occurs hot and cold. But once the engine is running, it will not stall or stumble. Only gives me trouble on startups. Where should I look next? What signals the computer on this engine? It has a hall effect switch in the distributor and a crank sensor. Any input is appreciated.
Old 10-30-04, 04:39 AM
Are sure there are no codes (that you just don't have a check engine lite)
Some engine control systems if you lose the TDC signal it will continue to find it by the dist position sensor till the next time you shut it off. (because it told once and is set with the dist sensor)
I would look at the sensor at the crank, that the one thats telling where TDC is.
Old 10-31-04, 08:52 AM
pt_fixer's Avatar
Yep, I checked with a scanner to confirm no codes.
How would I go about testing the crank sensor?
Old 10-31-04, 10:17 AM
My experience is if there are no codes and you have a no spark situation, then it's something that the computer dosen't watch.
Thats an OBD II vehicle...so it watches alot. Maybe a bad coil, cap, rotor etc. It dosen't monitor those.
