About BMW 318I
Old 10-30-04, 11:47 AM
calvito
About BMW 318I
HI,There I am new in this forums,so if anybody can help me with the following I really apprecciated. Thanks in advance.
I need to know what are the most importants part that I should check or change on a 1996 BMW 318I 1.9 liter with 145000 miles on it as a part of the regular schedule maintenance, the car is working fine now, just have problems with the rear bearings, but other than that seem to be ok.
Old 10-31-04, 12:21 PM
Same as any other car but I would check with a trans shop about the fluid change in that car.Are you sure the noise in the back is "just" bearings?I ask because if you have a rear differential problem it would be cheaper to fix before it totally fails.If I remember correctly the trans in the car could be a z or zf series and can be killed easily by improper servicing so check first.
Trackbacks are On
Pingbacks are On
Refbacks are On
