console to trany shifter cable problem
Old 10-31-04, 07:09 PM
mikedef
91plymouth sundance i cant sincronise the transmission with the shifter on the consoll i replaced the cable and had to find nuetral by hand on top of trany now dont know were the setting is for park so shifter cable is in right position
Old 11-01-04, 03:57 AM
the_tow_guy's Avatar
Received 29 Votes on 23 Posts
As long as you have known position on the trans and you adjust to the corresponding setting on the console, all of the positions should be correct. Are you sure you had the tranny in neutral - 2 clicks from Park?
I would get the trans into park and adjust at that point; everythng else will follow.
Old 11-01-04, 04:31 PM
mikedef
thank you tow guy
