1995 Didge Caravan Idle Problem
jnicholass's Avatar
11-02-04, 06:36 AM   #1
jnicholass
I currently own a 95 dodge caravan with the 3.0 engine. When the transmission is shifted into reverse or drive the engine start to idle rough causing the van to feel like it is jerking. I have changed the Spark plugs, Wires, distributor cap, rotor and EGR valve. Does anyone have any ideas on what can be done next?
carguyinva's Avatar
VA
11-02-04, 06:58 AM   #2
hmmm...
...have you checked for vacuum leaks, base ignition timing...clean the throttle body and check minimum air rate...
jnicholass's Avatar
11-03-04, 03:26 AM   #3
jnicholass
no not done any of them, thanks for giving me a place to start
