2000 Montana
Old 11-02-04, 05:58 PM
2000 Montana
Recently my heater fan has been acting up! When you turn the fan Knob from 0-5 the fan doesn't start blowing at all until you get to 4. What could possibly be wrong?? If the fan motor had a problem wouldn't it not work at all instead of just working on the high settings? Does anybody have a suggestion on what is wrong, any help would be greatly appreciated !!!
Thanks in advance,
Luca
Old 11-02-04, 07:33 PM
sounds like the resistor card may be bad
Old 11-03-04, 04:03 AM
carguyinva's Avatar
or the switch...
...it should be checked with a test light. or...try removing the resistor, it's located near the blower motor, and look at it...it's obvious when they fail because they burn up...these fail pretty regularly
Old 11-03-04, 09:03 AM
Where do I find the resister card? Is this something I can do myself ?Do I need to take the dash apart to get to fan motor?
Thanks in advance for all your help !!
Luca
Old 11-03-04, 02:28 PM
Under the right side of the dash by the blower motor.Fairly easy job to do.
