I don't know where this hose goes?
I have a 1988 Ford Mustang GT V8 HO and I'm attempting to put the Upper Intake Manifold back on, but I have a hose, about the diameter of 1/2" coming out from underneathe the front of the Upper Intake Manifold. Obviously this goes somewhere, but like an idiot I forgot to tag it. Can someone help me and tell me where this puppy is supposed to go?
You should have 2
The one on the drivers side should have an L after 2" or so, then loop back (still under the plenum), pop out the back and plug into the Barometric Absolute Pressure switch
The BAP is a small black box next to the long vacuum "multi-T" on your firewall
The other (pass. side) comes out front, goes behind the dist., hooks up with a wire loom and hangs with those wires till they get to the Canister Purge Solenoid just before the charcoal canister
Vac. line goes into the solenoid and short one goes out to the canister
