help
Old 11-08-04, 07:37 AM
kryptonite75140
Question help
my brother has a 82 f150 it out of the blue started to screw up with an extreme rough idle it is worse when it is in drive, timing is not off, not overheating . it has new plugs wires rotor ect. i am confused?
Old 11-08-04, 08:23 AM
fuel filter or pump?
vacuum leak?
Old 11-08-04, 09:29 AM
kryptonite75140
ok not fuel filter or pump no vacuum leaks ????????? cylinders maybe?
Old 11-08-04, 05:16 PM
Prometheus
might be obvious but check the oil? and/or oil pressure while running
Old 11-09-04, 05:55 AM
kryptonite75140
the truck has taken a turn for the worse now it sounds like a train
Old 11-09-04, 04:40 PM
Did you check the oil pressure as suggested?What engine is in the truck?Describe the noise better please.
