Stick Shift Transmission Question
Old 11-09-04, 01:52 PM
V
I have a 1993 Toyota T100 with a standard transmission. For sometime I have been feeling a bit of "unsmooth" shifting. It is as if I have to play with the stick to get it in gear as I shift. It does not take a lot of work but it is perceptible. I intend to pass the prpblem on to my mechanic but I was hoping I could get some advice before doing this. Thanks
Old 11-10-04, 02:29 PM
D
Probably due for a new clutch,slave or clutch master cylinder how many miles are on it?Is the clutch fluid full?
Old 11-10-04, 02:44 PM
V
It has 50,000 miles. Frankly, I wasn't aware of "clutch fluid" but I will look into the items you mentioned.
Old 11-11-04, 05:05 AM
the_tow_guy's Avatar
Received 44 Votes on 36 Posts
The reservoir for your hydraulic clutch master will be on the firewall to the left (looking forward) of the brake master. Uses standard brake fluid.
