Clutch replacement
Hi,
Today my clutch completely gave up on me. I have a 93 Mercury Capri N/A FWD. How hard will it be to replace the clutch myself with no prior mechanical skills?
It will not be the easiest thing you have ever done.I strongly suggest a good manual or an alldata subscription.You will need lots of tools also so be prepared.You will need a helper or a under car trans jack and I think you could rent that.Good luck.
