92 Ford Explorer - Transmission shift problem
I have a 92 Ford Explorer 5 speed. Occasionally when putting in nuetral, I cannot shift into any gear. I turn off the engine, and problem goes away. Any help would be appreciated.
Thank you.
Thank you.
Check the trans fluid level and the clutch master cylinder under the hood and add as needed.If you still have a problem you may have a clutch or internal trans problem.Certain Fords had the clutch slave cylinder in the bellhousing so check there for fluid leaking also.
Previous Thread
Next Thread
