Squeeky clutch 98 Tacoma
Old 11-12-04, 11:12 PM
sdoerr
I have a very loud squeek coming from under my dash when using the clutch. I have a 98 Tacoma v6 4x4. The problem occured once while still under warranty and was repaired. The dealer said it was a nylon bushing that was replaced. Is this a repair I can do now since the warranty has expired. Is it complicated or does it require special tools.
Old 11-13-04, 05:15 AM
Their is a TSB for revised parts depending on 4 cyl or V6.
PM your email address and I can send you the TSB
Old 11-16-04, 02:43 AM
A V6 you just have to replace the spring bushing and use no grease. May have to replace the pedal if it's worn through the bushing.
You have to remove the pedal/spring assy and it could be a pain if your doing for the first time.
