daytime running light
Old 11-14-04, 04:03 PM
D
Lightbulb daytime running light
where are the screws located for changing this light,on 2000 chevy silverado
Old 11-15-04, 01:50 PM
G
Received 2 Votes on 2 Posts
While your question is a bit vague, I am going to make a few assumptions.
First, is one light out - or both.
If one is out, then turn on your headlights. You will probably see that the same light is not working under night conditions.
The bulb is most likely halogen and is accessed from behind the lens assembly - without undoing any screws. A partial counter clockwise twist of the socket should free it.
One big No-No when you install the new bulb. Do Not touch the glass part of the bulb with bare hands or any oily rag. Any oils - body or otherwise, seems to considerably shorten the life of the bulb.
Old 11-15-04, 02:24 PM
D
Remove the 2 pins under the hood that retain the headlamp assembly and remove the headlamp assembly.You will be able to get to the bulb then.No tools are required and in about 2 minutes your are done.
