Antifreeze Dripping
Old 11-14-04, 07:58 PM
Antifreeze Dripping
I have an 89 Plymouth Voyager 2.5 turbo. Noticed some antifreeze dripping. Radiator seems ok. All hoses and clamps were recently checked out fine. There is no wet floorboards inside the vehicle to lead to a heater core problem.....any suggestions?
Old 11-14-04, 08:47 PM
C
Question
Dripping from where
Have you checked the water pump?
GlassesRx
Exactly where is it leaking? Water pump making noise? Squeeking? Can you please locate and give us some more info? Just pray it's not a head gasket! <g>! Good luck and let us know!
Old 11-15-04, 05:28 AM
Q
Also, if you notice it leaking badly, just fill it up with water & crank the engine. It could be the water pump gasket...but if you replace that, just replace the water pump while you've taken all that apart.
Old 11-15-04, 02:32 PM
D
Have the vehicle pressure tested to confirm the location of the leak then you can do the repair.This is if you can not say for sure where it is.
Old 11-16-04, 05:31 PM
We did have a pressure test done and it looks like the bypass hose was a little bit too short and that's where we were losing antifreeze. Thanks for all the replies ....You guys and gals are awesome
