expedition rear shocks
Old 11-16-04, 08:56 AM
R
royalet
I have a 98 expedition 4x4, and i am just tired of fooling with this air suspension, i have 5.4L, I want to know if i can switch to conventional shocks, if so do anyone know the conversion process
Old 11-16-04, 10:43 AM
carguyinva's Avatar
if it's a true air suspension...
...then it's more than just shocks. coil springs would replace the air springs. if it has a level ride type of thing that uses air in conjunction with the hydraulic shocks, you should just be able to replace the shocks with a high quality replacement and disable the compressor.
Old 11-16-04, 11:29 AM
R
royalet
expedition
actually iit does have a leveling supension, it lowers down when the ignition is off in the rear, and when its started it raises up, according to the weight in the truck
Old 11-16-04, 11:32 AM
carguyinva's Avatar
then...
...the conversion job is a much larger and more costly undertaking. try contacting a local parts supplier. some of the big suspension aftermarket companies like Moog make conversions...esp for fords...to convert them to a conventional coil spring and shock arrangement.
Old 11-16-04, 11:37 AM
R
royalet
expo
thanks, yeah i found a setup for about $260 conversion kits,
Old 11-16-04, 11:55 AM
carguyinva's Avatar
less than what i thought...
...good luck with it and don't forget to disable the compressor
