Knock, Knock.....
Knock, Knock.....
1993 lumina 2dr. eurosport....when i hit a bump in the road, sounds as if someone is knocking on the floorboard...i remember my friend the mechanic , replaced a 6 dollar bushing on my old cavalier when it was doing the same thing , but he has moved off to neverland and was just curious if anyone had some input onto which bushing he replaced? i remember saying it was easily done...any hints? thanx , Sal..........
Make sure you check the struts where the lower spring seat is they are known for rotting out there.You really need to put the car up on stands and check the entire front suspension and steering or have it checked at a garage and repair the problem yourself.
