brake calipers
Old 11-18-04, 09:17 AM
riverrunnerx
Exclamation brake calipers
Hey all, feel silly asking but frustrated. Am doing rear brake pads on a 90 honda prelude and can't seem to push the calipers back to accept new pads. Is there a trick to them I don't know? I find it hard to fathom that both rear calipers have seized on me. Anyone with advice would be greatly appreciated....Thanks.
Old 11-18-04, 10:51 AM
Received 2 Upvotes on 2 Posts
Rear Discs Brakes?
They often need a special tool that helps you rotate the pistons while pushing them in
"threaded" pistons, like a screw
Not sure what type (there are many) would be for a honda
Ask at the auto parts store
Or get a "multi" type tool (these'll get you by but not that easily)
Old 11-18-04, 11:18 AM
riverrunnerx
Talking thanks
Thanks for the info. had me going for 2 days....much appreciated.
Old 11-23-04, 07:02 AM
Lindsey
Did you open the bleeder (if it has one)?
Old 11-23-04, 03:01 PM
N
check the rear of the caliper. its quite likely there is a winding mechanism of some sort which will pull the piston back.
this might take the form of a plug or bolt which has an allen key bolt or something similar behind it.
a lot of jap cars have this for handbrake adjustment and winding pistons back.
Old 11-26-04, 03:03 PM
autozone will rent the tool necessary to complete this job.
Old 11-30-04, 05:12 PM
ficam99
brakes
Anytime you do brake pads always push the piston back first, before you use the rachet to remove the bolts that hold the caliper in place. All you have to do is place the screwdriver between the pads,or in a manner that allow you to push against them and push the piston in the caliper back. Also Auto zone sells a cube shaped tool that allows you to manually twist the caliper back to put the new pads on. I am not ase certified but have done many, many brake jobs.
