1997 grand caravan
Ren12's Avatar
11-20-04, 11:39 AM   #1
Ren12
1997 grand caravan
hello
I have a 1997 grand caravan, 3.3 v-6, with airconditioning. My wife has informed me that the heater is not blowing all the time. Sometimes it will work and others not. I asked if she could feel any heat. She wasn't sure but she said the windshield slowly defrosted. Any ideas. Something cheap I hope.
Thanks,
Rene
jeff67's Avatar
NC
11-20-04, 02:45 PM   #2
Make sure the coolant level isn't low. If the coolant level isn't low, you maybe have a thermostat that is stuck open. Do you have a temperature gauge on the dash? If so, it should be in the normal zone after 10-15 minutes or so after starting the engine. If it shows the engine is cold, when driving the van for a while, the thermostat (and gasket) probably needs to be replaced, which should be easy.
Those are the 1st things you should check.
Also, when is the heater not working? At idle or while driving, or just random times? I assumed the blower is working and its blowing cold air instead of hot air. Is that correct?
Ren12's Avatar
11-22-04, 05:12 AM   #3
Ren12
Hi jeff
I should have said the blower is not blowing as opposed to the heater not blowing. I apologize for the confusion.
trinitro's Avatar
11-22-04, 06:56 AM   #4
It it's running intermitently then you have a loose connection somewhere. There is probably no easy way to find these....
jeff67's Avatar
NC
11-22-04, 04:51 PM   #5
Does it operate properly at certain speed settings and not others, like does it work fine in the low speed setting? Or is it intermittant no matter what the speed setting is?
