96 Camaro V6 fuel relay
Old 11-24-04, 04:22 PM
Ravenkil
Hi,
I was just wondering if anyone knows off hand where I would look for the fuel relay on a 96 camaro with a V6. Thank You for any help!!!
Old 11-25-04, 09:36 AM
Not sure on your car, but on an '88 Regal I once had, it was in a small plastic box mounted on the left front inner fender. It was a plastic box, red I think, and contained the fuel pump fuse and fuel pump relay. Hope this gives you a starting point.
Old 11-25-04, 11:00 AM
Ravenkil
Yeah anything helps! Thanks
Old 11-25-04, 07:08 PM
partsguy
Are you talking about the fuel pump relay? If you are, it should be black plastic and have a stamping number of 3601.
Old 11-26-04, 01:39 PM
Ravenkil
Yes the fuel pump relay is what I am talking about. I read in a manual that it is under the driverside kick panel. The part number helps. Thank You for the information.
Old 11-30-04, 08:38 PM
Ravenkil
The fuel pump relay was under the driverside kick panel. Thank You everyone for your help!
