Help! The Power Window is stuck open.
Old 11-26-04, 05:50 PM
whlin76
Hi.
I have a 1994 Acura Legend LS Coupe. The front driver side window is stuck open. I took it in to my local Acura dealer and they told me that the Main Window switch is bad but they were able to "hard-wire" the window to close without replacing the switch. After I got my car back, I've accidently opened the window and I can't get it to close.
Can anyone help me how I can "hard-wire" the window to close? It's pooring rain out and I don't have a garage to park my car in!
Thanks.
Wen
Old 11-27-04, 02:12 PM
Basically, you need to figure out which pins in the harness connector that goes to the switch are shorted when the switch is in the up position and short them with a jumper wire(s), being careful not to short anything else in the process, including any metal parts of the door or body. Sorry I can't be more specific... I hope you already have the window up by now.
