Your opinon, 96 GrandAm
Friend took their car to Jiffy Lube (not my perferred method) to have the oil changed, two weeks ago.
Now the oil light comes on. They have checked the oil level and it is good.
Possible causes?
1. Bad sender
2. Bad oil pump
3. Clogged screen
4. clogged oil filter
5. loose wire
Did I miss anything? If Jiffy Lube doesn't do anything for them, I may be looking at this thing so any help would be appreciated.
What should the oil pressure be on this car? Sorry I don't know what size engine it has, but I am sure it is the most common for this year and make.
Possible causes?
1. Bad sender
2. Bad oil pump
3. Clogged screen
5. loose wire
I'm going to guess it has the 3.1L six in it. The only other engine is the 2.4L four.
Like I said, I haven't even look under the hood yet so I'm not sure of the engine.
However, if you have both pressures handy.....???????
Yes, I was wrong!!!! It has the 4 banger in it, 2.4L.
He says, "His wife took it back to Jiffy Lube and they couldn't find anything wrong. However, the light is now off." Hmmmmmmmmmmmmm
We will wait and see.
If you have the pressure handy on the 2.4L, let me know. I may go over and check it just to be sure.
