my 91 ford taurus 3.0 liter turns over wont start
Old 11-29-04, 01:19 PM
SimonVallore
Question my 91 ford taurus 3.0 liter turns over wont start
my 91 ford taurus 3.0 liter turns over wont start so far ive sprayed starting fluid in it reset the fuel pump made sure it had fire ect ect but it still fails to start its not sputtering as if it was a timing belt tho ive heard some wont show any signs of the timing belt going up im open for any ideas and if any one knows the fireing order for this thing could they please post ....all help apreciated....
Old 11-29-04, 02:16 PM
Check for spark on more than 1 plug wire,fuel pressure with a guage and injector pulse then post your findings.Those cars were bad for modules,coil and coil wires going bad.If you have sprayed starting fluid in the intake and it doesn't at least backfire I have a hard time believing you have spark.
Old 11-30-04, 10:41 AM
SimonVallore
How do you check for injector pulse ???
Old 11-30-04, 03:06 PM
You would need to remove an electrical connector from a fuel injector and place a noid light across the connector and crank the engine.If it blinks you have pulse if not you don't have pulse.I would check for spark and fuel pressure on that car first as it is easier.Remove the coil wire and see if it's corroded also.
Old 12-01-04, 02:05 PM
SimonVallore
ok the coil is now replaced but i just checked for spark and im not getting any there is also minor surface rust in the distributor wierd
