2000 chevy s-10 4.3 liter 6 cylinder
Old 11-30-04, 03:57 PM
ficam99
I put in a new directional assembly in the truck, the old one was unable to shut the wipers off anymore. Since I put this in I have been unable to start the truck. The directional assembly has the wipers, blinkers, washer fluid, all as part of its make-up. The truck seems like it wants to turn over but just falls short. The fuel pump has already been changed, I am at my wits end?? Any suggestions?? Thanks
Old 11-30-04, 04:17 PM
D
Try this,crank the engine and leave the key in the run position for about 10 minutes the security lamp should turn off.Turn the ignition off for at least 5 seconds.Do this 2 more times and the last time make sure you turn the key off.If this works the truck should now start unless you have damaged a connection during the switch replacement.Or blew a fuse so check them also.
