CAL
12-04-04, 11:23 AM
water diverter (heater control valve) question
Hi - Can someone explain if it's necessary to keep this thing on my ford ranger? Is the point to help the engine warm up more quickly? I'm curious, because I really dislike plastic parts like that in an important area, in terms of leaking. (mine is leaking...)
I'd like to just bypass the whole unit.
12-04-04, 02:20 PM
Chevyman
Heater control valve
It controls the coolant to your heater core. If you don't want to control your heat you can bypass.
CAL
12-05-04, 08:50 AM
Hi Davo - It does have a vacuum hose (but no wiring) going to it, but it is inserted in-line with the hoses going to the heater. There is a little throttle type valve that the vacuum controls, controlling how much water goes to the heater core.
I don't really know if I have an "auto position for the fan". I'm not sure which fan you mean, or how I could tell.
Thanks
Thanks
