tail lights out
Old 12-06-04, 06:51 AM
Brad92373
Unhappy tail lights out
83 chevie astro van. No tail lights. Put in new bulbs and new fuses, still wont work. I dont know what to do next. Help! Brad :
Old 12-06-04, 09:45 AM
I would check the voltage of the lights with the brake pedal down. Does it work with a turn signal? hazards? It may be wires, or it could be the brake light switch right behind your brake pedal.
Old 12-06-04, 10:24 AM
daswede's Avatar
If you can take out your taillight housing you may want to check the circuit board connections for corrosion and rust through. Only fix is to replace the ckt. brd. housing unless your handy with a soldering iron and can solder some wires to bridge the gaps that have been rotted away. Not saying this is your problem,but it was mine on both tailight housings.
Trackbacks are On
Pingbacks are On
Refbacks are On
