'93 rear wheelbearing
doa's Avatar
12-08-04, 12:02 PM   #1
doa
I have a '93 chevy cavalier rs stationwagon and need to replace the rear wheelbearing. what is the best why to go about doing that?
davo's Avatar
12-08-04, 01:50 PM   #2
Remove the wheel and brake drum then remove the 4 bolts holding the bearing in and remove the bearing.If you have antilock brakes a wiring connector will need removed from the backside of the bearing also.
doa's Avatar
12-09-04, 12:16 PM   #3
doa
to easy
sounds to easy. sense i got estimates of a half hour to 2 hours and prices from $200 and $400 to replace
davo's Avatar
12-09-04, 03:04 PM   #4
Sounds easy because it is,I could do it in less than 15 minutes.Remember you are paying probably an hours time at $60-$100 per hour depending on where you live plus an extra 40% more(minimum)for the part than you can buy it for.
