ford explorer
Old 12-08-04, 03:30 PM
mrtech3288
ford explorer
i have a used 98 ford explorer xlt it was just running so good and @ one morning it became a hard starting, i know that fuel injection type of car doesn't needed to step on the gas pedal everytime u want to start the
engine, but now i have to step on the gas pedal to start the engine and if i let it go, the engine will die. what do you think is the problem? do you think it's minor and i'ts easy to fix it or i can do it my self?
Old 12-08-04, 03:57 PM
Desi501's Avatar
There pretty notorious for vacuum leaks. With the engine idling, listen closely for a hissing sound and try to follow it. They have a lot of problems with rubber elbows connected to vacuum sources and supplying things like PCV or brake booster. The connectors tend to suck a hole right through ther connecter usually at the elbow.
Old 12-09-04, 04:21 AM
hogfan's Avatar
Will not idle?
The Idle Air Control Valve is probably sticking. Replace the valve. Basic part number is a 9F715.
