Wheel vibration at speed
Old 12-10-04, 06:20 PM
OHKP55's Avatar
Question Wheel vibration at speed
I have a 2000 Interpid that I bought off-lease. Ever since I bought the car, there has been a vibration in the front end as I get closer to 60. If I go over 75 (not that I ever would) the vibration seems to diminish. I'm running a set Kellys with <15,000, and had one tire and a wheel replaced. Neither the dealer nor the tire guy can figure out what's wrong. I can't tell which side it on either. The tires have been rotated every 6K (every other oil change; makes it easy to remember).
Old 12-11-04, 05:36 AM
the_tow_guy's Avatar
You don't say how many total miles on the car, but if alignment and wheel balance haven't helped, and you're sure it doesn't maybe have a bent rim, one or both CVs could be your problem.
Old 12-11-04, 06:27 AM
if your tires have worn unevenly at some point, an alignment and balance will not help until you replace the offending tire(s).
Old 12-14-04, 02:17 PM
OHKP55's Avatar
Front end vibration
The car has around 73,800 miles. A rim and two tires have been replaced. Rotation and alignment have not helped.
