Gas smell
Gas smell
I have a 1993 mercedes, I have noticed a strong gas smell coming from the vehicle. even when it is sitting, but I have not seen any leaks on the drive way. What else could I look for or check?
A leaking gas cap,evap cannister or vent hoses could cause the problem.Have you looked under the hood for external injector leaks?I think if you sniff around you might be able to get closer to where the smell is coming from.
