removing inside door panel
Old 12-15-04, 08:31 AM
I need to remove the inside door panel on a 2000 ford explorer to replace a passenger side mirror. Thanks for your helpl
Old 12-17-04, 02:59 PM
hogfan's Avatar
Door Panel?
Steps
(1) remove the 2 screws above inside door handle
(2) remove the inside door handle cup (black plastic trim just pry off covers door handle.
(3)Start in a lower corner and work around the door panel pulling out
to disengage the pin-type retainers
(4) Lift the door panel up to disengsge from window trim
