98 Jeep rad fan stays on... help!
hobbes68's Avatar
12-20-04, 04:20 PM   #1
hobbes68
I've got a 98 Jeep Cherokee that has the additional cooling fan for the rad.
Lately, when I turn on the A/C or defog (much more apparent in cold climate condition), the additional fan will spin up. Then, when I park and remove the key from the ignition, the fan stays on. It's stayed on for >2 hrs, and reached a point where I removed the fuse to stop the fan.
The temp gauge reads normal, so I can't understand why it stays on so long.
I've had the battery replaced recently, and also the coolant system recharged, so those are the only two things I can think of that might be tied-in to the problem.
Any ideas how to fix this would be much appreciated!
jeff67's Avatar
NC
12-20-04, 04:50 PM   #2
The cooling fan relay might be stuck closed. Try swapping it with another relay of the same, possibly the other fan's relay if its the same.
hobbes68's Avatar
12-21-04, 04:25 PM   #3
hobbes68
will try...
Thanks Jeff67,
I'll check the relay and give it a try!
