1996 Mazda 626 - gas odour
Old 12-26-04, 04:35 PM
Mully
I have recently noticed a strong gas odour filling up my garage once my car is parked and has cooled down. There is no visble signs of gas pooling on garage floor just a pungent gas odour. No signs of gas consumption increase as well.
Any insight would be appreciated.
Old 12-28-04, 10:59 AM
marvinhilton
Check all the rubber gasoline hoses under the hood. They will sometimes crack, often a pattern like cracking, due to age and engine heat. Sometimes short sections of the hose will be covered with a spiral like plastic cover, so be sure to slide these back or pull them off and look for cracks and dampness. Especially look for hoses in the back of the engine compartment in the firewall area where the heat is often the highest.
Old 12-28-04, 01:56 PM
Overfill?
Do you over fill the tank because it could get sucked back into the carbon canister under the hood and you would smell fuel.
Dont overfill tank stop when it clicks off(no more)Well just enough to round the amount off like 4 cents is ok.
