heater control
Old 12-27-04, 08:04 AM
K
heater control
I had i problem with my 95 ford ranger overheating. I changed the tremstat, fix the overheating problem now my control switch for heater does not work correctly. The blower mower control works find but the control for defroster stays in the defrost mode. I check all the fuses I know to check. can you help me with this problem thanks
Old 12-27-04, 03:12 PM
D
If the truck is stuck on defrost you should look under the hood for a vacuum hose broken or disconnected provided the adjustment still moves(lever).
