2000 Jimmy,, No Heat
Old 12-27-04, 01:08 PM
W
Kinda need some help diagnosing my problem.
2000 GMC Jimmy 4DR, 4WD, 78K miles.
The fan works fine, blows on all levels. No leaks. Radiator and overflow are full(original dex-cool). Truck does not run hot, normal operating temp.
With the fan on and the temp turn to hot,, it blows fine,, just "cool" air, except when I accelerate,, the temp seems to get a little hotter. Now for a little more info on the dex-cool,, about a month before I noticed the heat didn't work,, the truck took a "gulp" of dex-cool,, I asked a mechanic about this and he told me,, for some reason these model GMC's will do that, about every 30 to 40K miles. The amount of the "gulp" was about a quart maybe 2,, there was a little bit left in the overflow.
My first thought was the thermostat. My next thought was the heater core. I asked a few "backyard mechanics" about it,, they said everything from the thermostat to a plugged heater core or flat out bad heater core. I bought a new thermostat (wishful thinking), but now I can't even see where the thermostat is on this truck . Anyway,,, any ideas will sure be appreciated,, thanks in advance.
Old 12-27-04, 01:48 PM
G
Received 2 Votes on 2 Posts
While you are waiting for others to check in, you may want to go on any search engine and type in dexcool. There are a number of problems being reported with this coolant.
Old 12-27-04, 02:11 PM
D
Flush the heater core with a garden hose and you should be fine.I would flush the entire cooling system as you are pushing the limit on dexcool at 5 years.The thermostat is right on top in the front of the intake.
Old 12-27-04, 02:18 PM
W
WOW,, is flushing the heater core with a hose, easy????????????????
I might have a problem with the garden hose thing anyway,,, its 10 degrees right now. LOL. If I took it to a "10 Minute Oil Change" place that does "cooling system flushes",, would that work??????
Old 12-27-04, 03:29 PM
W
Geez,,, after doing some research on this dexcool,, it appears as if I have nothing but problems on my hands for a while. Looks like dexcool is a chonic problem with these GM engines and Gm refuses to acknowlegde it. I guess I have another question now,,, can I flush out the dexcool and replace it with regular anti-freeze??
