1988 pontiac sunbird waterpump repair
How difficult is it to replace a waterpump for a 1988 pontiac sunbird? Does anyone have any idea on how to replace it?
You would need a service manual because the timing belt needs to be removed to do the pump.I would suggest replacing the belt while you are in there.A special whench is needed to adjust the timing belt tension after reinstalling the belt.On a scale of 1-10 I'd give it a 7.With 1 being easy and 10 being hard.
