12-28-04, 02:11 PM
memito4267
Starting Problem(electrical)
12-31-04, 05:05 PM
memito4267
My vehicle is a 97 Chevy GMT400 Pickup, automatic, 6 Cylinder engine. It cranks over and starts eventually but drains alot of the battery until it finally starts. Thanx.
01-01-05, 04:27 AM
I would start with a fuel pressure test in the morning and see what the pressure is.If you want you can pull a hose off the air intake,shoot in some starting fluid,reattach the hose and see if it starts right away.If it starts quick it likely needs a fuel pump.If you use the starting fluid method have a fire extinguisher handy just in case it backfires.
