air conditioning maintenance
Old 12-30-04, 08:08 PM
R
rob
rob is offline
Hi - I've always heard that it's good to run your air conditioner a little bit now and then, all year long to keep seals lubricated.
In the winter time, does using the air conditioning as a heater count in keeping all of the seals lubricated?
Thanks
Old 12-30-04, 08:17 PM
hogfan's Avatar
Defrost uses the A/C
When you use the DEFROST you operate the A/C system. On Most cars and trucks.
Old 12-30-04, 10:56 PM
R
rob
rob is offline
Thanks hogfan! So, do you think using the AC regularly does help keep things lubricated? If so, do you think using the defroster once a week is good enough?
Old 12-31-04, 02:15 AM
Desi501's Avatar
Yes, on both counts.
Old 12-31-04, 04:51 PM
C
But doesen't the AC compressor not engage below certain ambient temperatures? So don't you need to try to do this on warmer days so the compressor will run?
