Old Problem...just hoping
Old 12-31-04, 05:19 PM
G
Guitarman500
I have a 1994 Acura Integra LS.
Sometimes the car doenst start, it makes the noises as if the engine wants to start but it cant...I installed a Fuel Gauge so that I can monitor how much fuel is goin through and whenever this problem occurs it indicates that no fuel is pumping...Im going to check the fuel pump relay and possibly replace the fuel pump. I just wanted another opinnion...could this problem be caused by anything else besides the fuel pump?
I have had a Tune Up/Replaced O2 Sensor and the car runs much better now but the start problem occurs on occassion.
P.s. The Engine does have spark during the nonstart.
Thanks Again!
Old 01-01-05, 09:09 AM
Well it seems as you diagnosed you problem, no fuel pressure.
What you could do next is to use a test lite at the fuel pump to see if power is present when it doesn't start and has no fuel pressure.
There is another post on the forum http://forum.doityourself.com/showthread.php?t=186282 that’s states there is relay under the dash having a problem with the solder joint. Sounds like it’s worth a look.
