electrical help
Old 01-01-05, 05:10 PM
sammy004
electrical help
Can anyone help me out I have a nissan micra and it does not start I checked all these in order.
-I checked the spark plug wires no spark.
-then I checked the coil no current.
-then I cheked the wires going into the coil for 12 volt still not power.
can anyone tell me where I can look next. I check the fuses under the dash all good. (well the seam good)
any help would be greatly appreciated.
Old 01-02-05, 06:53 AM
D
I've never heard of a micra but if you don't have 12 volts at the coil it will never run.You may need a wiring diagram but checking the ignition switch would be a good start.Also if you have an aftermarket remote start or alarm I would remove it and see what happens.
Old 01-02-05, 12:10 PM
sammy004
I have no remote starter the engine cranks over but it just doesn't hold the ignition. I'm thinking its a fuse somewhere.
