2001 ford ranger anti lock brakes
jwilliewonka's Avatar
01-03-05, 10:20 PM   #1
jwilliewonka
Help!
I replaced front rotors, and pads. Now I have a ABS warning light that comes on only once I have moved the truck. I suspect that it is a sensor not reading one of the sensor rings (reason) when I installed the new wheel seal I hit the sensor ring tilting it, I did straighten it out but is was not in the same position as before. Also when I pushed the pistons back into the calipers I opened the bleeder valve so as not to overflow the master cylinder resivoir. Any sugestions or should I just hang my head and take it to the dealer?
Thanks
hogfan's Avatar
01-03-05, 10:32 PM   #2
It could be that sensor ring but I have seen alot of rear speed sensors go bad. That would not related to the repair you did. Need to pull codes from the ABS system.
davo's Avatar
01-04-05, 04:22 AM   #3
If you cracked or dented that reluctor ring it could make the light come on.Also both new rotors need to be the same brand I had trouble by changing just 1 rotor several years ago.
01-04-05, 09:19 AM   #4
jwilliewonka
Thanks guys, Looks like it is time to take it to the dealer.
